Hi - I searched the forum but no luck, is there a command where I can add to the ONINIT to run the batch 'add to search DB' function for a specific folder?
This way each time I open up VDJ it will automatically add the newly added songs within that folder.
thanks
thanks
geposted Sat 28 Mar 26 @ 4:38 pm
There's been a watchFolders option since 2023...
geposted Sat 28 Mar 26 @ 4:47 pm
