Topic: Disable MIdi 2.0 through Virtual DJ?
I've been having stability issues and cracking in the audio when using VDJ for a bit now.
I was reading a post on the VDJ facebook page that says if I am a windows user I can turn on EarlyAccess in VDJ and after a restart I can search for "disable midi 2.0" in the settings.
I have enabled early access, but there is still no option to disable midi 2.0 in the settings.
Is this a thing? What can I do to get this to show up? Running Win 11 and VDJ version v2026 b9005
thank you!
geposted Mon 30 Mar 26 @ 5:42 pm
You need build 9245. the disableMidi2 option is in "missing controller" tab and in settings.
https://virtualdj.com/download/build.html
This isn't related to crackling audio however, that's a completely separate issue.
thank you!
If that function is using the CFR logic from something like the vive tool, that will stop working at the end of April when the new MIDI stack drops out of the Controlled Feature Rollout phase and the check is removed from Windows.
Pete
Microsoft
