Hi, all of a sudden, I cannot connect to VDJ on either my desktop or laptop. Are the VDJ servers down?
geposted Sun 05 Apr 26 @ 2:22 am
servers are not down at the moment.
Just disconnected and reconnected to check for you.
check internet connectivity, with a "speed checker" of your choice (since you say its both laptop and desktop)
else, check hosts file troubleshooting from the wiki
https://virtualdj.com/wiki/checkinghostsfile.html
geposted Sun 05 Apr 26 @ 2:31 am
I followed the instructions for the host file but no change. Internet connectivity is normal.
geposted Sun 05 Apr 26 @ 2:49 am
Fixed. For each WIFi connection in Windows 11, I had to change DNS settings. Thanks.
geposted Sun 05 Apr 26 @ 3:49 am
