Topic: ModernEQ / XDJ-AZ not cooperating
I'm completely lost. I'm trying to get ModerEQ working with XDJ-AZ. No matter what I do, channels 3 and 4 play exactly like 1 and 2 high/mid/low traditionally. I also did a clean install of Virtual DJ. Any thoughts?
geposted Wed 08 Apr 26 @ 4:05 pm
1) You need to switch decks 3 & 4 to software (PC) source in XDJ-AZ itself
2) Decks 3 and 4 must not have any song loaded
3) Then you need to switch the eqModeDual option to "Outer"
4) Finally select your preferred eqMode (ModernEQ)
Then it should work, meaning that turning the EQ knobs on decks 3 & 4 will change stems on decks 1 & 2
