Hello,
When I use the ROLL button to activate stems...VOCAL | MELODY | BASS pads all light up in different colors. The DRUMS pad does not light up blue. Can I midi map this pad to a color?
I already reset to factory mapping, but the DRUMS pad does not light up blue.
geposted Thu 09 Apr 26 @ 4:06 am
Which Stems Pad are you having the issue with?
Believe there are maybe 4+ pads that feature stems.
And you reset your Stems Padpage?
The most likely cause of a pad_page not working, as expected, is that its script was accidentally modified.
Which is easy to do since there is no save function(popup or icon) in the Pad Editor, and clicking any verb in the action window will change the Pad Page script.
And one can check the pad you wish to be blue and see what color is set for the pad.
1) open Pad Editor
2) click the pad of issue
3) click the "Color" Tab
to check the script that sets the color
maybe it should be color "blue"
(with auto-dim check box checked.
hope that helps
with more infomation, maybe able to assit more.
1) open Pad Editor
hope that helps
geposted Thu 09 Apr 26 @ 4:49 am
