Hi, some questions about stems as a new user.
I want to use virtual dj to export track acapellas so I can use them live while djing. I tried exporting the some songs as a test and the quality was great, but I noticed a couple things.
1.) When exporting acapellas it exports them with the song in the same folder. Is it possible to only export the acapellas themselves without any other song files?
2.) I looked in the folders where the exported acapellas sit and noticed that they're each individually in their own folder, I guess to mimic how pioneer gear reads from CDJ. The names of the files also just say "acapella" and are housed in a folder with the song's name.
Is it possible to change the naming scheme/change where I save these acapella stems?
Hopefully my question made sense. Would appreciate your help on this, thanks!
geposted Thu 16 Apr 26 @ 6:28 pm
No and No
geposted Fri 17 Apr 26 @ 8:42 am
There is 3rd party software available at a cost that can do this for you.
geposted Fri 17 Apr 26 @ 8:57 am
@kradcliffe what software is that?
geposted Tue 21 Apr 26 @ 12:02 am
UVR is free :-)
and probably the best imo
geposted Tue 21 Apr 26 @ 12:35 am
