Version 2026 b9295
"Moov atom not found" for VDJ recordings.
Guys please help or fix.
M
M
geposted Fri 17 Apr 26 @ 8:43 am
dublinmike wrote :
Version 2026 b9295
Moov atom not found for VDJ recordings.
M
M
Temporarily installed 2023 and that worked, I hope a solution can be found because 2026 is absolutely brilliant!!!
geposted Sat 18 Apr 26 @ 8:39 am
geposted Sat 18 Apr 26 @ 12:59 pm
The issue is fixed already in current EA release.
Note that it only happened when recording as webm, while mp4 would probably be the better choice anyway
geposted Sat 18 Apr 26 @ 2:12 pm
I was definitely recording .mp4, but that's great news anyway, thank you Adion.
geposted Tue 21 Apr 26 @ 7:49 am
I just re-updated latest 2026 but no joy with .mp4s, not playing in VLC either.
geposted Tue 21 Apr 26 @ 7:58 am
With EA Build 9295, i can properly record in both mp4 and webm and the recorded files play fine with VLC too.
geposted Tue 21 Apr 26 @ 9:31 am
Perhaps check the video recording hardware acceleration option
geposted Tue 21 Apr 26 @ 9:34 am
Interesting, never knew that existed. I got the job done in 2023 anyway, just not sure why 2026 would be any different. I'll go play with that, thank you for your help , as usual you are generous with your time.
geposted Wed 22 Apr 26 @ 10:23 pm
Thank you Adion, makes no difference.
geposted Thu 06 Aug 26 @ 10:05 am
