I just updated to 2026 pt two and the audio in many of my older songs now has a noticeable buzz on bass hits:
https://mega.nz/file/5VtlxZLI#0smeUjXf5X7d-QQpAnI4USL7WtmdtLFILx15EmSMdpU
I'm using a DDJ1000 with ASIO, what's going on? This is completely unuseable
geposted Sun 26 Apr 26 @ 9:55 pm
What is pitchQuality and scratchFilterQuality set to?
Does it change if you use pitchQuality 4 or scratchFilterQuality 30?
geposted Mon 27 Apr 26 @ 6:32 am
they were set to the default, 3 and 14. at 4 and 30 the buzzy effect is still present in some songs but seems to be less noticeable overall.
geposted Mon 27 Apr 26 @ 12:41 pm
which is the song you posted btw to make it easier to compare?
Also, master tempo enabled, controller used, and which samplerate the audio is set to might be helpful
geposted Mon 27 Apr 26 @ 12:54 pm
It would be useful to also state ASIO buffer size (and if you tried adjusting), and whether the track is at the original key (if not, how much it's shifted, and up or down) and the original tempo (if not, how much is it sped up/slowed down).
[adion beat me to it 🤣]
geposted Mon 27 Apr 26 @ 1:18 pm
