Topic: VDJ freezes and goes nonresponsive upon start-up.
I have tried to uninstall and reinstall but still happening I have had this issue once before and just restarting the computer fixed it but not this time.
geposted Wed 29 Apr 26 @ 10:57 pm
You need to give a lot more info for anyone to help.
Yeah no the new build definitely has some issues. Mine started freezing on macos (m1) as soon as I updated. Doesn't load any songs, just freezes and becomes non-responsive after I try to browse. So now I downgraded to previous version and works fine.
I have no freezing issues on my M1 or M4 Pro for any recent release, so it's more likely a personal config/setup issue.
If you have any type of column that reads directly from the file always (I believe File Date is one), or you have autoAnalysSongsOnView and you are browsing a folder withva lot of unanalyzed files, it may be contributing to the problem.
