Topic: Software randomly changing bpm
On my friend's virtual DJ, all the tracks she plays on A are at a slightly higher pitch and BPM than it should be, and vice versa on channel B, they're all slightly lower and slower than they should be.
I've turned off auto pitch, and any options involving the BPM, but I can't figure out why her system does it.
Can anyone give me any hints as to resolving the issue? She doesn't have a clue about how the software works, and it's mildly annoying.
geposted Sun 03 May 26 @ 4:56 pm
So if you load the same track on both decks, they have different BPMs?
Do you have a controller connected?
