Hi,
I have come across an inconsistency with the fluid grid analysis when using keyboard command "browsed_file_analyze fluid" compared to when using the BPM Editor analysis.
The above is a screen shot of the analysis with the BPM Editor closed. Being able to perform a batch analysis with the keyboard command is great but i'm getting inconsistent results.
The above screen shot is of the analysis in the BPM editor. The gridding from this image is also resulted when i have the BPM editor open, but perform the analysis with the keyboard command in browser.
I've tried to test it a few different ways, by reverting to the rigid analysis, but the same results each time. Everytime i close the BPM editor and perform the analysis i get the inconsistent gridding.
The above screenshots shows the same results on a different track.
geposted Sun 10 May 26 @ 8:15 pm
UPDATE:
Have just tested this bug on Build 9295 and 9246. The issue is not replicated on 9246.
geposted Sun 10 May 26 @ 8:40 pm
