it will be fine , if we can define the scale of the jogs ( 1 turn = x second) for pitch bend & scratch . a shortcut for disable the jogs too , because sometimes i don't need them but they are so sensible so sometimes they turn when i use the cross fader .
_ Is it possible to personalise the buttons of the console under vdj, because dj console mapper is not ok .
geposted Sun 30 Nov 03 @ 9:25 pm
use beat lock button on the console for enable & disable the jogs wheels will be better i thing ( with backlit when enable) .
geposted Mon 01 Dec 03 @ 7:50 pm
I'd also like the possibility to modify the pitch range ie 4% or 2%.... (in addition to the already possible values)
geposted Tue 13 Jan 04 @ 9:08 pm
