Am I OK to update my Prime 4 to the latest firmware / software and still work with VDJ? Thanks!
geposted Thu 14 May 26 @ 6:45 am
Someone reported last night their Prime Go plus wasn't connecting to software after the 5.0 upgrade so probably better waiting to see if this is a widespread thing.
Rolling back to previous firmware won't be easy either as they have changed the way Album art is handled so it's a new database and file format.
Also seems that people with LC6000 players can't connect to other decks or controllers either.
Being such a big update it will unfortunately have bugs and in the past it's taken them months to put patches out.
geposted Thu 14 May 26 @ 6:57 am
I will wait then! Thanks!
geposted Thu 14 May 26 @ 7:46 am
I'll try my Prime 4 with VDJ later and see what happens.
[a few moments later]
Yes, seems fine here.
geposted Thu 14 May 26 @ 7:50 am
Thanks!
geposted Thu 14 May 26 @ 10:33 am
the lc6000 is not connecting to the sc6000 so be aware
geposted Fri 15 May 26 @ 1:26 am
An update has been released that fixes the LC6000 issue.
geposted Fri 15 May 26 @ 10:11 am
yes i can confirm that its working fine now
geposted Fri 15 May 26 @ 6:21 pm
