Forum: VirtualDJ Skins
Topic: Kontrol D2 Screens (Possibly others too)
Hi,
About 5 times out of 10, when i start up my D2s, the screens don't recognise VDJ, the buttons all work but the screens get stuck on showing the original Traktor message. It makes not difference that I can tell if VDJ is started before the D2s or after.
Once I have one D2 running if i then start the second it will always get stuck on the traktor screen, the buttons will work.
I'm running VDJ v2026-m b9295, macbook 2021 M1 Tahoe 26.5, D2s firmware upto date. Although these issues have been happening with older versions of software.
I've tried having both decks connected to seperate usb ports, daisy chained, through a powered hub and it still happens.
Does anyone know a fix for this? Does it happen to screens on other devices?
Thanks
Bryn
geposted Thu 21 May 26 @ 9:42 am
So it happened earlier, and the only way to resolve it was to open Traktor which the d2s recognised, then close traktor and open vdj. Maybe this is more of a bug than a skins issue.
