Trying to replicate a brake on stems effect when the vocal is isolated the instrumental brakes rather than just hard mutes. I’ve written some custom macro but it doesn’t do the desired effect. From what I see the “brake start” effect applies the whole track and can’t be applied to a single stem. Any other way to achieve this? Thanks!
geposted Sat 06 Jun 26 @ 11:58 am
You can use the VinylBrake effect, which does allow to be used on stems
geposted Sat 06 Jun 26 @ 12:03 pm
Thank you Adion! Would you have any syntax for a vocal isolation applying a vinyl brake to the instrumental? Been messing with this for sooo long. No problem if not! I’ll keep trying!
geposted Sat 06 Jun 26 @ 12:18 pm
padfx vinylbrake 8bt "stemfx:MeloRhythm"
geposted Sat 06 Jun 26 @ 12:23 pm
I'm looking for the same effect as above. Where does the "padfx vinylbrake 8bt "stemfx:MeloRhythm"" get placed? Or I should ask: Where do I find the code to enter that command?
geposted Fri 12 Jun 26 @ 1:57 pm
the pad or button you press
pad editor
pad editor
geposted Fri 12 Jun 26 @ 2:02 pm
Thanks!
geposted Fri 12 Jun 26 @ 2:47 pm
