Topic: cannot login to virtual dj
having trouble signing in ...cannot login as a user....???
geposted Sat 06 Jun 26 @ 2:01 pm
Stephane Clavel wrote :
It could be that your ISP (Internet Service Provider) or your router, is not respecting the TTL (Time To Live) of our DNS, and is still caching some old value.
To check this, open the Windows command prompt (CMD+S and type "command prompt"), then type "nslookup live.virtualdj.com".
If the result is not 3.33.237.122 and 15.197.187.49, then the problem is with your ISP or router DNS.
The recommended solution as mentioned above, is to use the standard google DNS.
