Topic: Batch change tracks to rigid beatgrid
The new fluid beatgrids are absolutely atrocious, is there a way to make it so that all my tracks are on a rigid beatgrid?
I can change each track one by one to rigid via the BPM editor but there doesn't seem to be a way to do it for all tracks and I've got a 50,000~ track library with a lot of them being detected as fluid.
Thanks,
Ellie
geposted Fri 26 Jun 26 @ 3:28 pm
filter
Fluid = 1
to get an isolated list.
then create a RSI scroller to load to deck call
set_fluid 0
then check browser_scroll bottom?, if bottom stop RSI, if not bottom browser_scroll +1, and the repeat will go again
If you search scroller on site there will be a few examples in search results.
Curious for some titles of tracks that were incorrectly detected as fluid, were wrong in fluid and were correct in rigid though
locoDog wrote :
filter
Fluid = 1
set_fluid 0
Muito obrigada! I'm gonna give this a shot now but I appreciate the help :)
It's not about them being incorrectly detected as fluid, it's more the way that I DJ just doesn't work with it. II use a lot of the tracks which have slow and drawn out intros before going into standard 4/4 but during those intros I want to mix in other tracks and use the sync button so everything is matched precisely but it just makes it all a bit messy for me
Normally an intro shouldn't trigger automatic fluid scan though, especially if it actually aligns with the intended bpm
