Hello VirtualDJ Support Team,
I hope you're doing well. I would like to ask about the compatibility of the new Hercules DJControl Inpulse 200 MK3.
I'm not sure if it is already supported, but every time I try to use it with VirtualDJ, the software doesn't recognize the controller. Since it's a very new model, I understand that support may not be available yet.
If it isn't currently supported, I would like to kindly request that compatibility for the Hercules DJControl Inpulse 200 MK3 be added in a future update.
Thank you for your time and all the great work on VirtualDJ!
geposted Fri 03 Jul 26 @ 2:01 am
