As these settings seems confirmed to be global and not per deck, these settings will be powerful as per deck variable.
Being able to fine tune the frequency for each deck on the fly can make a real improvement to Virtualdj features and djs in general. Not that kind of huge use case scenario but pretty high level customization ability.
geposted 7 days ago @ 6:33 am
check say:
eq_low_freq to control the equalizer Low Freq
which is similar to
eq_low which will control, either the Bass Stem or Low Freq, depending the mode the equalizer are set ( "Frequency", EZRemix, or ModernEQ.)
and to have them act on an single deck, use either action_deck 1, or deck 1 in front of the verbs.
(depending on the situtation)
which is similar to
geposted 7 days ago @ 8:20 am
Thank you for your answer IIDEEJAYII,
This is not a frequency parameter it is just a bypass of EQ setting ModernEQ/EZRemix to force the behavior of the bass knobs, if i am not wrong.
This doesn't act in modding any cutting frequency, what is the goal of equalizerXXXXFrequency.
Appreciate the advice btw.
Thx
Thx
geposted 6 days ago @ 1:54 pm
