Hello,
I am using a mac and no matter what cant get my g4v to connect to the software or really any software. When I plug it in, it doesn't pick it up at all. I have no idea what to do. It says download drivers, but theres no drivers for the g4v. Please help.
geposted Tue 07 Jul 26 @ 12:11 am
could be related to this not sure https://virtualdj.com/forums/269337/VirtualDJ_Technical_Support/Windows_11_KB5095093_Allows_Relief_to_The_MIDI2_Problems.html
geposted Tue 07 Jul 26 @ 1:28 am
1) OP is using a MAC
2) Gemini G4V is actually a HID and not a MIDI device.
I will try later to see if I can locate mine, but one good test would be to first make sure that the controller itself hasn't been toasted.
So, does the same G4V work on any other system? (Windows or MAC) ?
Just to make sure it's not an issue with the board.
Also G4V is a quite old device now. I'm not sure how well it will work on a modern MAC (especiall one with M processor)
geposted Tue 07 Jul 26 @ 9:38 am
