Hi all,
Since 1 week, I got a message from win11 like that :
I ve tried to unable midi 2.0, but doesn t change.
I m on Win11 with a traktor S2MK3. It seems that microsoft block specific drivers that are not certified.
Do you know the reason or how to solve that ?
Thanks.
Thanks.
geposted Thu 09 Jul 26 @ 10:28 am
If you check the Native Instruments forum, you will see that there have been issues recently with Windows blocking NI drivers. There has been a statement from Jeremy @ NI saying they're working with Microsoft to resolve it. How long that will take is anyone's guess.
geposted Thu 09 Jul 26 @ 10:33 am
Thanks, I ve found the post : https://community.native-instruments.com/discussion/50775/known-issue-blocked-traktor-drivers-in-windows-11
Hope that come soon. I ve not find how to bypass this bug actually. (expected using wasapi mode)
geposted Thu 09 Jul 26 @ 11:02 am
I va ask the question to NI, and that is the answer : https://community.native-instruments.com/discussion/51262/niks2m3usb-sys
The problem is that I ve bought a VDJ license to use with traktor S2MK3, and if NI does not correct his driver, I can throw away my controller and lose my VDJ license.
geposted Thu 09 Jul 26 @ 9:34 pm
I solved the problem with ASIO4ALL. You need to download it, install it, and then select it in VDJ audio preferences. Hope this can help others.
geposted Sat 11 Jul 26 @ 6:40 pm
Hi Wassing,
Could you tell how to connect our traktor control s2 mk3 controller with virtual dj with use of asio4all
Could you tell me the step by step process
geposted Sat 18 Jul 26 @ 4:19 am
Hi, Sorry to answer late.
Native Instrument have release this new driver for Windows : https://drive.google.com/file/d/19_yegKyIMbVBGSVnfVpSmx47obYFcWog/view
But If U want to use asio4all :
Install Asio4all and select your soundcard on the left panel. Disable all the other (with the power icon); Then unselect on the right panel all the button (radio) like ont this printscreen.
Hope this help.
Hope this help.
geposted Wed 09 Sep 26 @ 1:58 pm
