Topic: Build 9482 bricks Mac
Hi everyone,
Just wanted to share my personal experience using build 9482 with a djm 900 nexus, two cdj 3000 players and an m4pro mac:
When cdjs are connected, the programm wont even start, you just get a spinning wheel.
If you connect the cdjs after starting the programm, you experience lag, sometimes the song doesnt play full (one song played as if i removed the "beat" stems which i didnt)
Using the vinyl break effect showed the effect on screen but the program simply paused the music.
Sampler (i put mine on deck 3) didnt work at all.
CPU usage spikes sometimes.
Had to downgrade to build 9295. No problems at all on that build.
I know 9482 is still an early access version but I just wanted to let you know
geposted Thu 09 Jul 26 @ 9:55 pm
