Thanks Phantom for clearing up that the Deck order in the Mapper should indeed be 1, 2, 3, 4, and is not causing the described issue.
Wanted to continue with more details from post 6 days ago.
Summary: All the knobs do work in controlling the audio correctly, if one does not pay attention to the labels on the skin's knobs, for the EZRemix and ModernEQ.
note: Full 5 stem layout shows labeling correctly)
And that the check box to select "Freq on inner channels" and "Freq on outer channels" descriptions are reversed, to their functioning for EZRemix and ModernEQ.
(refer to screenshots in post 6 days ago, above)
here are few screen video captures of some labels maybe not displaying, as one would expect.
(videos can be played full screen and stopped for closer examination)
1) note using EZRemix, when "Freq on inner channels" is selected, all 4 channels display Freq
and when "Freq on outer channels" all channels display EZRemix Stems.
https://gyazo.com/e0a8610795bd46320dfe96c6d7a1c333
2) similarly, when using ModernEQ, and "Freq on inner channels" is selected, all 4 channels display Freq
and when "Freq on outer channels" all channels display ModernEQ Stems.
https://gyazo.com/67b69d0329b40738722b984b5e9a4d26
3) If the Full 5 stems, configuration is used, all labels display as expected, and the selecting check box functioning is NOT reversed as is the case for 1 and 2 above.
https://gyazo.com/4ece3a80ccb053ed3edae065b1c8e5d9
note: for 1) and 2) the labels will change when rotating the controllers knobs as was shown in Blueberryaliens video.
and again the great news.... the audio does indeed respond correctly when using the knobs with say freq on outer and stems on inner, but labeling may be confusing.
don't remember it working this way, when stems were first introduced. And since I don't use this configuration, cannot say for sure when or if it changed.
also not an important issue for me since, as mentioned don't use this setup, and wanting to post in case if is helpful to someone
default Pro skin
default mapping for Denon MC7000
9482
win 11 latest update
disableMidi2 NO
mixerOrder 3124
default Pro skin
9482
disableMidi2 NO
mixerOrder 3124
geposted Sat 18 Jul 26 @ 8:43 am
So I didn't take a look at the video, but when I tried on Mac what I saw was when EQ dual mode was selected and either Modern EQ or EZRemix was used, the EQs worked correctly, but both sets of EQs controlled the same deck panel, with the deck panel changing its mode according to what the channel EQ was set to control.
Not a huge issue functionalitywise but it still is an issue from a visual perspective, similar to the PFL lighting in EQ Dual mode. Full 5 stem in EQ Dual mode functioned as expected visually (as you stated).
This happened on non default skins too when I tried, so it's might not be a skin panel logic selection issue.
geposted Sat 18 Jul 26 @ 12:26 pm
Default settings make no change. And yeah the audio works as intended but not on the screen, way too confusing to use.
geposted Sun 19 Jul 26 @ 2:40 pm
