Hello. Since the last update, a "fluid" mode setting has appeared in the PPM section. For every part, I have to right-click, open the PPM editor, and switch the setting from "fluid" to "rigid" to suit my needs. Is there a way to set this automatically in the preferences? I haven't found anything on this—I want all my audio files to default to "rigid" mode. Thanks.
geposted Tue 21 Jul 26 @ 11:16 pm
locoDog wrote :
filter
to get an isolated list.
then create a RSI scroller to load to deck call
set_fluid 0
then check browser_scroll bottom ?, if bottom stop RSI, if not bottom browser_scroll +1, and the repeat will go again
If you search scroller on site there will be a few examples in search results.
Fluid = 1
set_fluid 0
if the writing the rsi is over your head just say and I'll write it up and send it in a PM
geposted Wed 22 Jul 26 @ 1:26 am
