Topic: hercules t7 owners....
Just purchased a T7
Would like some help from other owners....with set up questions
Re the pitch bend function...how is this operated... currently its shifting between hot cue points.
geposted Thu 23 Jul 26 @ 10:54 pm
this goes over how everything is mapped on that controller. It doesn't appear to have any pitch bend buttons on it btw
https://virtualdj.com/manuals/hardware/hercules/inpulset7.html
i have to assume you are referring to the parameter buttons see this image
the knobby sides of the jog wheel is normally used for bending on controllers and the top flat surface for scratching
sup
ppl been saying the parameters buttons can be used for pitch bending .....
And they can, if the buttons are remapped to the right script.
Anything that sends midi in can be mapped to any action verb.
any one have the script to map the parameter buttons to function as
