Topic: Sync not staying synced?
I have to spam my sync button just to keep things aligned when I'm mixing this didn't used to be an issue for me, just started happening after a recent update
geposted Tue 28 Jul 26 @ 1:07 am
Sync has always been a one time alignment operation, not an always on mode.
I have never had an issue with sync doing what it's doing until this recent update. I will have 2 songs with the same bpm, and it just will slowly go out of alignment on the beatgrid. For example I can put 2 house songs at 130, and it will just move out of place over time with one of the tracks. This is an issue I've experienced while on pioneer hardware but never with VDJ software
Eli Gartman wrote :
I have never had an issue with sync doing what it's doing until this recent update. I will have 2 songs with the same bpm, and it just will slowly go out of sync. For example I can put 2 house songs at 130, and it will just move out of place over time with one of the tracks. This is an issue I've experienced while on pioneer hardware but never with VDJ software
this is in regards to rigid analysis not fluid
setting autobpmStabilizer off
setting fluidAnalysis manual
If you are using a controller, perhaps the jog wheel is sending spurious messages?
