Topic: Focusrite Scarlett 4i4
Hello, I bought a Focusrite Scarlett 4i4 to use two stereo decks, but nothing is working in stereo—only Deck 1.
When I go to the audio settings, select "Split Deck 1," and choose the Scarlett 4i4 with channels 1 & 2 for stereo sound, it works; however, there is no output for Deck 2. Even after configuring everything in Focusrite Control 2, nothing seems to be reaching the Scarlett 4i4.
Thanks for your help.
geposted Sun 02 Aug 26 @ 8:53 pm
A screenshot of your VirtualDJ audio configuration while trying to use the Scarlett would help a lot.
Generally speaking, you should use channels 1+2 for master (or deck 1 if you use an external hardware mixer setup) and channels 3+4 for headphones (or deck 2)
