Hi,
I'm using Dual Deck Automix and want to manually set the BPM of the incoming track on Deck 2 before the transition.
For example:
Deck 1 = 128 BPM
Deck 2 = 120 BPM originally
I manually set Deck 2 to 110 BPM
When the Automix fade starts, VirtualDJ changes Deck 2's BPM back to 120 BPM instead of keeping my 110 BPM setting.
I want Deck 2 to stay at whatever BPM I manually set before the transition and for the third song, which will play on Deck 1 again, I want it to be the songs original BPM. Logic is, unless i manually change pitch then it should be songs BPM. I have tried many settings without it working.
I see similar threads but I don't know how they fixed it if its the same issue. Im on Macbook.
https://virtualdj.com/forums/191524/Wishes_and_new_features/Master-Tempo___Automix.html?utm_source=chatgpt.com
https://virtualdj.com/forums/212639/VirtualDJ_Technical_Support/Pitch_Preset_no_longer_works.html?utm_source=chatgpt.com
https://virtualdj.com/forums/207717/VirtualDJ_8.1_Technical_Support/Disabling_beatmatching.html?utm_source=chatgpt.com
For example:
Deck 1 = 128 BPM
geposted Tue 11 Aug 26 @ 10:06 pm
setting automixTempoMode
geposted Tue 11 Aug 26 @ 10:24 pm
I have tried this and have tried all mods and all mods without achieving what I want. It's also automatic and will keep same BPM for all songs.
geposted Wed 12 Aug 26 @ 12:09 am
Will use this which atleast allows me to adjust the next song to the BPM of current song. It activates "Keep BPM" until i press it again on the button editor and deactivate it. I have created 1 that changes for 1 song only. But I think this is more complicated than it has to be.
toggle '$AMManual' & var '$AMManual' ? setting 'automixTempoMode' 'keep bpm' : setting 'automixTempoMode' 'normal tempo'
geposted Wed 12 Aug 26 @ 1:41 am
