Topic: Changing default 32 beat timing on visuals
Hi, I tend to use the Visuals on a large screen as it helps to engage the audience. Once "suggestion" I've had from a customer is that the visuals change too frequently - on checking the default seems to be every 32 beats.
I don't want to have to change them manually, but so far I've had no luck with lots of different AI/Google suggestions for changing the default 32 beats. I don't mind programming a custom button or assigning something to a keyboard shortcut, but can anyone help with the script needed?
Thanks in advance!
geposted Wed 19 Aug 26 @ 10:54 am
if windows I have a plugin that does it, if not windows it could be a script
where are you calling visuals?, on deck, on master, on audioOnlyVisualisation, because it matters
