I saved the configuration as a preset that I use for EQ10 on the master deck.
EQ10 activates automatically at startup. I did this from Settings → Controllers → Keyboard → Advanced Editor, find ONINIT, and add:
deck master effect_active "EQ10" on
When I open VDJ, EQ10 activates. However, when I connect the Pioneer DDJ-1000, EQ10 deactivates, and I have to manually re-enable it. Is there a way to prevent EQ10 from deactivating when the Pioneer is connected?
geposted Thu 20 Aug 26 @ 4:22 pm
Read your old thread
https://virtualdj.com/forums/269849/General_Discussion/I_can%27t_get_EQ10_to_stay_permanently_activated_in_VDJ.html
Moderator Thread Locked 🔒 as duplicate
geposted Thu 20 Aug 26 @ 4:30 pm
