There used to be a way to toggle the options for videoCrossfader directly from the skin. That way if I wanted to quickly stop VDJ from automatically showing video from the playing deck and manually select my video source, I could do that with the click of a button. It used to be located right next to the crossfader. I think it was just a checkbox or maybe radio button? But recently I haven't been able to find that on the latest default skin. Was it moved or even removed from the skin completely?
If it's gone, can someone give me the VDJ script code to make a custom button that toggles the setting of videoCrossfader from "Smart" to "Separate" and back again? Thanks in advance!
geposted Thu 20 Aug 26 @ 7:38 pm
video_output
geposted Fri 21 Aug 26 @ 12:57 am
Found the setting on the skin. Right click on the video output window.
geposted Sat 22 Aug 26 @ 9:38 pm
