Topic: Midi mapping for stems in scratchbank
Hi i know its not natively possible to load a particular stem with a track in scratchbank- but does anyone know the midi mapping script?
E.g for a particular page in my scratchbanks i want just the accapella to load and the rest of the pages to load as full tracks etc.
I know you can do this in sampler so im assuming the script is do able.
Tia
geposted Mon 24 Aug 26 @ 7:49 pm
It's no different to muting/solo-ing a stem of a song on deck, all scratch bank is doing is loading a deck to a cue point
after the script that's there add for example
& only_stem vocal on
as all rightclick/shift+press call scratch bank unload, depending on a few things you might want to add something there, maybe some stem state saving on the normal click before scratchbank_load_...
so that shift click can return to the saved state of the non banked track
perhaps your stem reset settings might come into play, I'm not sure.
