https://streamable.com/p1niqc
If frequency EQ is in inner channel, stems EQ does not work as intended in outer channel (Instru and bass sliders nonexistent)
/Theres also another bug that keeps happening where the EQs reset but I cant tell what triggers it. Ill stay in touch/
geposted Mon 24 Aug 26 @ 10:03 pm
Seems mostly fine on my end (no sound as I forgot to turn on the main mixer, but you don't need the sound to see it's working ok)
geposted Mon 24 Aug 26 @ 11:14 pm
I have not tested the "Keep frequency using channels 3 and 4" off (but I wonder why one would want that given you have the stems and frequency controls separate and dedicated to decks 1 and 2) or other more thorough use cases but in general it's doing the right thing, where it wasn't before for those middle stem modes.
geposted Mon 24 Aug 26 @ 11:19 pm
Odd. We have the same controller and I tried selecting stems eq manually instead of using my toggle button and I still run into the same issue...
geposted Tue 25 Aug 26 @ 12:54 am
