Search_Playlists only works when it feels like it; sometimes it works, and other times it doesn't !
Sometimes all the playlists are found, and other times they aren't
geposted 2 hours ago
So I've noticed this behavior on occasion as well - I haven't narrowed down the correction but normally I change the focus to the folder track list, de-invoke the function then click itno the browser tree, then re-invoke it and then it works.
There is definitely an issue with it working sometimes though.
geposted an hour ago
hi team
we are unable to buy the licenses.
Hi DJ Vinyltouch,
I don't understand what you mean. What do you mean by "de-invoke the function"? There is no deactivation involved;
I trigger it using a custom button.
