How does that rank with other stem separators??
geposted Tue 08 Sep 26 @ 7:23 pm
So does Engine actually do aim to eventually do it online (reading up how zplane is supposedly light enough to be done on CPUs, at the expense of quality and more latency).
How does that compare to DEMUCS and AudioShake's implementation (which Algoridim licences for DJay Pro/Neural Mix) and VirtualDJ (which you guys pretty much kept under wraps or I don't know where to look)?
geposted Tue 08 Sep 26 @ 7:39 pm
After some reading I think I have found a way to replace Denons stems with VDJ lol!!
geposted Tue 08 Sep 26 @ 7:57 pm
I hate to brake the news, but at this point we feel that we need to warn our users to wait and not buy the Prime 4 G2 if they care about using it with VirtualDJ.
InMusic (Denon) claims that support for computer software is coming "soon"
However, at this point, we, as VirtualDJ developers, don't even have a firmware that supports computer MIDI mode to work with.
In other words, we are stuck at waiting inMusic to get ready to release a firmware that will support MIDI, and afterwards we can start working on integration.
This means that "soon" is not that soon..
We don't know how much time inMusic will need to prepare the firmware.
We do know (can estimate within a safe margin) how much time we will need to finish the integration after the release of that firmware.
We also don't know how much time inMusic will need to test/verify/confirm our integration and fix any possible bugs on their side.
So, at this point we don't feel that "soon" is a correct term, rather than "some time in the next few months"
Therefore, if you plan to buy a Prime 4 G2 with the intention to use it with VirtualDJ, please be warned that support may not come soon after all, and that we cannot do anything about it.
geposted Wed 09 Sep 26 @ 7:39 am
Here's what Denon posted the other day which suggests the delay is with "partners" rather than them.
geposted Wed 09 Sep 26 @ 7:48 am
You are all grown ups.
You can choose which one to believe by your own!
geposted Wed 09 Sep 26 @ 7:57 am
Thank you for your information and your "warning". Just to understand correctly. You don't have a midi enabled firmware to work with for both devices (System One and Prime 4 G2)? Or just for the Prime 4 G2?
But in any case, I would like to support VDJ with alpha/beta testing as soon as there is anything to test :-)
Once again, thank you for your hard work!
geposted Wed 09 Sep 26 @ 9:49 am
This thread is about Prime 4 G2.
geposted Wed 09 Sep 26 @ 10:00 am
the SOUND INSURGENT wrote :
Off topic but getting closer 😝
I’ve converted around 15 files and each have played and sounded better then the Engine files 👍🏾
where can I get this converter?
geposted Thu 10 Sep 26 @ 11:18 am
groovindj wrote :
Regarding stems, there have been some posts on the EngineDJ forum recently where somebody's figured out the Denon encryption and (presumably) vibe-coded an app to import stems from other places.
Not tried it myself but I'm curious as to how Denon will react to this, and whether they'll allow the app, or maybe add some import options to their own software.
I posted on the Denon forum that I had managed to import stems from other applications, e.g. VDJ or Nuo Stems, into Engine. Definitely no vibe coding involved.
I didn't create the tool Huey is using though, and I didn't provide implementation details to anyone. I didn't fancy the legal implications.
That said, the encryption key is not hard to obtain and to anyone who knows anything about encryption the format used isn't hard to work out either.
I did also speak with someone I know at inMusic about their stem quality though.
geposted Fri 11 Sep 26 @ 10:55 am
Did they give you any insight as to whether better sounding ones were coming?
geposted Fri 11 Sep 26 @ 3:02 pm
Hi there, first time poster - Apologise if this amounts to not much...
The latest beta enables audio to parse through the Denon G2 - But there is no controls mapped currently. I've tried myself to map basic PLAY and CUE buttons but they don't work as expected.
What works - Audio passing through, Cross faders appear to work fine. (When Omnimode enabled on controller for corresponding decks)
The functions though are NOT replicating on the Virtual DJ Software.
Faders appear to operate independently to the software so that probably needs mapping.
Play button not working - But I don't know if this is a scripting issue or something on drivers side. (Most likely)
Got Cue button to work but it just plays the song and doesn't work as expected. But Play button probably needs a specific instruction to function correctly.
Have not tried linking other buttons as yet. Just need to try and understand the method for mapping better.
At least in Omnimode the audio is passing through the controller. So thats a positive :)
I wouldn't recommend even attempting to use this in live environment as yet.
geposted Mon 21 Sep 26 @ 2:47 am
There's no native support for the G2 yet - from any DJ software.
Even the Rane System One is not natively supported yet, by anything other than Serato, after more than eight months (but on the way apparently).
Omnisource is not like simple MIDI mapping.
geposted Mon 21 Sep 26 @ 9:59 am
We will announce on our hardware page when the compatibility will be unlocked:
https://virtualdj.com/products/hardware.html?view=soon
Selected as best answer geposted Mon 21 Sep 26 @ 1:03 pm
Algoriddim have just gone live with their System One support.
Denon are saying once one's out of the gate, support for others should be quicker...
geposted Tue 22 Sep 26 @ 4:17 pm
System one just got Alogriddim support, so I imagine VDJ is in the pipeline in the next few days.. as it was simply a matter of firmware approval by Inmusic
geposted Tue 22 Sep 26 @ 5:46 pm
Hello everyone,
I wanted to ask if there are any updates on when the Denon DJ PRIME 4 GS will be supported by VirtualDJ.
Is there perhaps any new information or an estimated timeline for when support will be available?
Thank you in advance for your feedback!
geposted Fri 23 Oct 26 @ 12:18 pm
This information is still valid.
geposted Fri 23 Oct 26 @ 12:30 pm
As we've all noticed there's a lot of development in Open Source OSes and software by AI assistance (vibecoding by LLM's).
Today Akai, (part of the Inmusic group) announced a new product called the Akai Samplekey, and guess what. Its OS is open for community too. Not directly Denon Prime G2 related perhaps. But hopefully things will speed up now? Actually, a bit funny story behind this Akai release; Yesterday Berhinger announced a sort of AKai MPC ONE clone (they're good at this.. :D). OS not developped yet, it's only a render, some specs and OS will be Open Source. (Oh. Behringer even annoucned some DJ controllers, which seemed to be equipped with a touch display also).
But It's incredible what's can happen in like 3 weeks since an OS for another piece of gear went Open Source. For examplle with the M VAVE FM1 I bought in july this year. Nothing special and limited then. But in only 3 weeks after the OS went open source there's even more than +100 OS versions made available. And some made this little crap box turn in to an excelent groove box, offering functions taken out from gear with prices 10-20 times higher. I tested a few and it's runs very smooth. I actually only had some complaints on a paid version, the only paid version available till now as far as I've found. So if coding doesn't cost that much and time is like nothing, what are we waiting for Inmusic ; Denon and Rane??? :D
Ok seriously. I don't know how these things will work out, or if this will change things, but how patient do we need to be for Inmusic to make things happen?
The Akai MPC 3 (which I bought last year) and the MPC X G2 seem to be equiped with the same processor (SoC) as the new Prime 4 G2 and Rane Control ONE. Am I to optimistic about this?
geposted Wed 28 Oct 26 @ 1:47 pm
Open Source, as much as it does help with progress and leveling the playing field, has its own hinderances well - because if it truly is open source, then anybody (including people with malicious intent), can contribute, so security and reviews have to be that much better.
More LLM generated code means even more stress on the review team, which could mean things that shouldn't get in do get in.
Also, once you release something in the professional realm, you have to maintain it for people depending on it.
In most cases it's just one guy that had an issue and vibecoded something to solve it, but you have to ask yourself
A one man show for a product that came out post coding agent explosion is a red flag to me, even if they are charging, because professional software is complex, and one man looking in will miss things, and the project has a higher chance of just being abandoned if he/she disappears. I rather just take the time and do the project myself then, given the help of LLMs, rather than depend on a one man show.
There is a space for professional usage of LLM however, any dev not using it in some form right now is most likely underperforming to some extent. However, professional software is considered such because of the points made - you can't just rush something like that because you have an entire industry depending on you.
- What are the goals of this project?
- How seriously do they take professional use of this?
Are they keeping up with CVEs on components they may use? Do they even know the code well enough to make proper judgement calls or are they just shelling it out to LLMs to solve everything? - Will he/she maintain this indefinitely?
geposted Wed 28 Oct 26 @ 2:01 pm
