Topic: Club Setup
I have the following config
2 xdj 1000mk2 + DDJ-XP2 + djm900 nexus.
Can I use the above setup linking the two xdj and the mixer via ethernet and the mixer + DDJ-XP2 via USB?
I already and successfully tested 2 CDJ2000NXS2 + DDJ-XP2 + DJM900 NXS2.
Looking at the specs both XDJ and DJM900 has ethernet cable and USB ports.
Just to be sure.
Thanks in advance!
geposted Wed 09 Sep 26 @ 7:41 am
So there's no way to use those with VirtualDJ?
Maybe connecting all via USB.?
Yes, of course connecting all of them via USB will work!
After all, they are all supported devices!
Perfect... need to test the setup before...as usual... thank you very much!!!!
