Topic: lyrics issue
hi all
plz we need the words to appear from right to left in the dynamic lyrics
as some languages show in the wrong sequence.
geposted Sat 19 Sep 26 @ 4:47 pm
What do you mean by dynamic lyrics?
Both the Karaoke and the Lyrics video plugins already recognize right to left script
see here its from left to right when it should be right to left
this is the dynamic effect in lyrics
On which VirtualDJ build are you?
And what's the name of the song
I'm on 9642 the beta
but this issue was present on all previous versions too since the lyrics AI has been released
and with all non-English and arabic songs
There was a fix since this early access build:
Quote :
BUILD 9480 (2026-06-24)
-RTL support in Karaoke plugin
But apparently you mean it doesn't work.
As I don't speak Arabic, as an example, can you give a random word or a short sentence (from lyrics editor) and how it should display on the screen for you so I can test too.
Just the song title would be easiest so we can try with the actual song you have issues with
sure
the title is
abdul majeed abdullah yabn elawadem
once you search in youtube it will be the first one and this is how it looks
and this is a part of the lyrics
في عز ما كنت. أبواب قلبي خذتني. في عز ما كنت. أبواب قلبي خذتني. في عز ما كنت. في عز ما كنت. أهوج فيك وأفتح لك أبواب قلبي. خدعتني رجلي لبابك.
Thanks, I see the issue.
no reply since.
any updates guys
has beeb solved in latest early access. well done guys
