Topic: Spotify and STEMS
Hello, I just installed the new Part3 update. Spotify is available again, but the stems aren't working. Is this only happening to me?
geposted Mon 21 Sep 26 @ 7:35 pm
There are no stems with Spotify.
Is there a technical explanation for this, or does it again have legal grounds
It's the terms Spotify set to use the API. No stems or offline cache at present.
Okay, thanks for the explanation. In my opinion, it will not be able to prevail. Why should I use Spotify when Deezer and Tidal have stem integration
Go ahead, it's your choice to make.
I don't think Spotify has agreed on STEM or offline usage for any DJ Software integration, but I could be wrong...
Im sure they will add STEM's again sometime, It was nice when they had them back in the day.
