So when i plug everything in to start a set, my DDJSB2 default's to HOT CUE so i physically hit MANUAL LOOP button on the controller, but for some reason, within VDJ (in the areas that show each deck near the top of vdj) it sets it to something else like stems, so when i try to use the pads to create a manual loop, it obviously adjust stems. So I have to manually change this to manual looop for each deck. How do i change this in mapping or settings to ensure these are aligned. thank you.
geposted Fri 02 Oct 26 @ 2:21 pm
You can change which button selects which pad page, perhaps this was changed?
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html
geposted Sat 03 Oct 26 @ 5:49 am
