Topic: Cue Pad settings
Hi everyone,
I’m using VirtualDJ with a Pioneer DDJ-200. I’m having an issue with the CUE button.
When I press CUE to set or return to the cue point, the actual cue position seems to be off by around 1 inch on the waveform/jog wheel. It feels like there is a small delay or distance between where I set the cue point and where the music actually starts.
What setting should I adjust to make the CUE point more accurate and responsive?
I’ve already checked some of the jog wheel and scratch settings, but I’m not sure which setting affects the CUE position.
Any help would be appreciated. Thank you!
geposted Sat 03 Oct 26 @ 6:19 am
setting smartCue
