Topic: Spotify no search results
Hi Folks, just wondering if anyone is having the same issue as me when searching for songs on spotify. I get no search results even when the spotify section is highlighted. It was working fine yesterday but not today. Thanks for any feedback
geposted Wed 07 Oct 26 @ 7:23 pm
yes i am getting the same thing. Any help would be appreciated.
Thanks for confirming Darren
can also confirm
No search results from Spotify
Going to Spotify's main folder in Online Music and entering say "Love"
the results window, still says "Use the search bar to search"
same results if searching from a Spotify sub list
Note that Spotify is up and does populate all Spotify lists, and does stream them.
Just NO search capability available.
SPOTIFY NO SEARCH RESULTS not working in VDj -9644 anymore I just see my folders from SPOTIFY
bonjour j'ai le même soucis es ce quelqu'un a trouver une solution je suis en detresse la jai pas fine de telecharger mes sons
It's working OK in Rekordbox, but Djay Pro is having the same issue (according to a post on their forum).
Can confirm having the exact same issue. Not yet tested on other DJ software so wondering if it's an issue local to VDJ or not. I can load and play music from my playlists though.
Not working for me either, but tested in DJAY Pro and is working there as normal, so this seems to be with VDJ itself....
Seems to be back up and working again now :)
bien joué je viens de regarder tout refonctionne merci a vous tous de vos réponses vous êtes les meilleurs
The error I got was "there was an issue with accessing the Spotify integration" its telling me to update my VDJ software to the most recent version. I currently have version b9644 and that's the latest version. Any help would help at all. thanks
