Hi all,
So it's all on the title. Right now on the Remix view you have to choose between the 4 options but I'd like one side view with Remixes and one with Links.
Any way to do this?
Any way to do this?
geposted Mon 19 Oct 26 @ 9:15 am
Yes
Needs a custom browser skin edit and <filelist> pointing at one of these.
I do skin edits for a small commission.
GeniusDJ:\livefeedback
GeniusDJ:\similarsongs
GeniusDJ:\remixes
GeniusDJ:\linked
geposted Mon 19 Oct 26 @ 10:08 am
Thanks, will look at this, I was thinking looking at skin anyway! Appreciate it :)
geposted Mon 19 Oct 26 @ 10:51 am
A dedicated skin may be the better choice.
And an alternative, if one wishes to continue with current setup, one can add the wanted Sideview shortcuts directly in settings/options.
Just add/type the wanted shortcuts directly as below
Note: this still requires one to select the wanted sideview shortcut from the tabs at bottom of sideview.
Remixes and Linked will only be visible one at a time.
But allows easy access to each.
geposted Mon 19 Oct 26 @ 11:06 am
Ah yes works!
geposted Mon 19 Oct 26 @ 11:22 am
