Topic: Migrating from DJAY
Hi, I am attempting to migrate to VirtualDJ from Djay Pro. However, I am already getting into trouble trying to transfer some playlists with cue points via OneLibrary. VirtualDJ can read the playlists, but when I want to load one, it basically crashes. Has anyone else experienced this?
Any other ways to migrate cue points etc?
On beatgrids: I work mostly with rock, so fluid beatgrid is a must. Is there a way to set fluid beatgrid analysis as the default analysis mode in Virtualdj?
Thanks, Chris
P.S.: I made a quick screen recording of the issue but I guess video upload is not possible here?
geposted Sun 25 Oct 26 @ 8:51 am
For Fluid:
Change the fluidAnalysis option to "auto"
I cannot help you with OneLibrary. It works fine here (I just tested), but I don't really use it extensively and I can't tell if it's an issue on how VirtualDJ reads it, or how Djay wrote it..
Tbh, imo OneLibrary was never really meant for cross application transfer, it was meant for making USB drives for use with Pioneer/AlphaTheta standalone gear.
You are better off using tools that were made/better tested for cross application library transfer. In that regard, two tools stand out - Lexicon (the free version is sufficient for library transfer) and DJCU (one time fee I believe) and they keep DJ software metadata (cues, loops, grids, ratingratings, etc) intact, mostly with no oddities (e.g. correction of beatgrid shift for mp3s across software).
@PhantomDeejay and @DJVinylTouch - thanks, that already helps. I'll try again with another export from Djay to OneLibrary. Otherwise, I'll take a look at Lexicon - DJCU is mac only, I'm on a windows machine.
