Topic: CAN'T ACTIVATE THE SOFTWARE
have two laptops and activated my license on the two, I deactivated the license and formatted the drives and installed clean windows, now I tried activating the software on the two laptops but there is a message showing I have activated the software on four machines and can't activate the software.
geposted Mon 26 Oct 26 @ 9:44 pm
I'm not sure what you mean by activate. When you start the program it asks you to log in with your email and password . If you've done that and you have used the email that is attached to your license it should be unlocked
