I have an automix list which is all classical so I want to use the "radio style" fade where the current song fades into a cold start of the next song. The problem I'm having is VDJ is sometimes adjusting the tempo of the next song.
For example:
track 1 is 90bpm / 07A
track 2 is ~144bpm / 12A
... automix sets pitch on track 2 to -1.4
(I should note these are loading from spotify - I have not tested with local tracks.)
SETTINGS
audomixMode: radio
fadeLength 2.0
autoMixBeatMatchOnFade: no
automixTempoMode: normal tempo
autoBPMMatch: no
autoPitchLock: no
autoKey: no
autoBPMStabilizer: no
Any ideas?
For example:
SETTINGS
audomixMode: radio
fadeLength 2.0
autoBPMMatch: no
autoPitchLock: no
autoKey: no
Any ideas?
geposted Thu 29 Oct 26 @ 5:40 pm
Have you opened the automix editor and gone through each part where it goes to the next track to make sure they're all set for MatchBPM off?
every single track in the list has to be clicked on one by one to make sure beatmatch is off
and for a quick refresher:
Setting and disabling "Auto" options
https://youtu.be/B2Sb2qOYaSc
geposted Thu 29 Oct 26 @ 9:01 pm
I was just about to mention this. Automix editor is a gid send. I created a 1hr long mix using it and it already gathered me 6k views and 44 new subscribers on youtube. I really dont care about any of that stuff, but just goes to show you hiw useful and effective the automix editor can be.
geposted Thu 29 Oct 26 @ 9:31 pm
Hi, how do you deal with licensing?
geposted Wed 04 Nov 26 @ 4:30 pm
