Topic: Backspin problem
Hello,
I’m having an issue with the "backspin" effect. When I trigger it from the FX tab, it behaves abnormally, the music doesn’t stop after the effect ends. However, when I trigger the same effect using a custom pad I created, it works exactly as it should. The custom pad contains only the text: "backspin 4bt".
I’m not sure why this is happening or how to fix it; if anyone could offer some help, I’d appreciate it.
Here is a link to a video demonstrating the issue:
https://youtu.be/CumsZio1tSQ
P.S. I forgot to record what the backspin script looks like for the custom pad, so I’ve included an image instead.
geposted Fri 30 Oct 26 @ 1:01 pm
the backspin action and the backspin effect are not the same thing, check the effect gui for button states.
Could you be more specific? I don’t know exactly what are you talking about, but if helps, it worked normally and from nowhere start s to act like this.
I don’t know if any update broke it.
Thanks
Now I get it, I have two options, beats that are setting 4 beats and strenght setting in 50%
I took a settings file that I had saved last year as a backup, deleted the current one, and pasted in the old one; the backspin issue persists. I think this rules out any configuration changes I might have made—though I don’t recall making any.
Could it be a bug in the program?
I have two laptops; it works normally on one, but not on the other. I checked the native_Backspin.ini file, and both have the exact same parameters.
The only thing I did to the laptop which backspin not work correctly was to install some pads. Could there be a conflict between one of these pads and the backspin function?
From legacy list
@devs this legacy/new thing is going to continue without a change.
retire legacy as native, allow for download under 'old_*' name?
@locodog It worked, when my effects are full list I got the strange behavior, when set to legacy it works as I know, is this normal?
