Topic: Automix skipping when loading new song
When playing songs in automix, when the next song loads and then starts to play there is a slight pause or skip with both songs ( not sure how else to explain it) when the next song goes to play, both songs like pause for what seem to be a millisecond and it sounds like a bit of a skip. The songs are not in a streaming service they are on my local drive. Its been doing it for a while but i have been living with but I can't anymore. I was thinking it might be a graphics setting? idk Thanks!
geposted Wed 04 Nov 26 @ 9:37 pm
I have a similar issue where the start of the incoming song is missing. I did report it years ago but was never resolved. Not every song but it does happen frequently.
What is the Automix Type you are using ?
Yes, exactly. Its not all the time but it does happen frequently.
I use fade remove nothing. The length is 0 seconds. However, I always use the automix editor to tweak the mix on all the songs. I also usually overlap the two songs over many bars. Thanks!
That's the same as me. Will test again later to see if I can get a recording of the issue.
