Topic: Quantize hot cues?
Hello sorry if this is the wrong place for this question, but is it possible to quantize hotcues? Rekordbox has this feature, and I've found settings to quantize *setting* the hotcues, but I'm not sure if I see one for the hotcues themselves. Smart cue doesn't seem to he what I'm looking for either.
Thank you!
geposted Fri 06 Nov 26 @ 3:59 pm
If you don't mean quantizing "setting" the hotcue, and you don't mean "smart_cue" which is quantized jumping between hotcues, then what exactly do you mean ?
Sorry but I think Smart_Cue is what I was looking for, I think I had some other settings that had me conflicting with it a bit but playing a bit more I think I got it figured out! Thank you!
