Apparently an issue with flx10 On macOS 27 “Golden Gate” (2026), the DDJ FLX10 can show “No Audio Driver” if the FLX10 Setting Utility isn’t running or the driver isn’t installed for your OS — the fix is to update firmware, install the latest Mac utility, and manually launch it." What does that mean search doesn't find "Setting Utility" it was working yesterday when I set up as a new ImacM6 installed the drives etc and got it working but today logging in same issue but I forgot how I solved it. Ty,
geposted 28 minutes ago
You need to navigate to System Settings > Privacy & Security and unblock the pioneer driver for it to initiate correctly in future.
geposted 22 minutes ago
ty for your reply, I don't see in "privacy & security" anything about Pioneer what tab would it be under?
geposted 16 minutes ago
No idea, I just remember from the last time I had a mac about a year ago.
geposted 10 minutes ago
found it DDJ-FLX10 Setting utility searched for it in "finder" dragged it to the desk top now, when i manually activate it works, sucks we have to do that now. Thanks for you help.
geposted 9 minutes ago
