I was using Soundswitch last night with virtual DJ for several hours with no problem at all. (Wifi off as I don't use internet when DJing). Halfway through my set Soundswitch randomly stopped working and shows "Not Connected" for Virtual DJ. Since then it just simply won't connect. The only way to get connection to work is if I turn on wifi, it then connects fine again. But without wifi being on it no longer works. I have uninstalled and reinstalled Bonjour, I have checked to make sure the firewall settings are all as they should be, and made sure the OS2L settings are as they should be and I just can't seem to get this to work without having an internet connection. (I can turn wifi off straight away and it seems to stay connected).
Any ideas on how to resolve this?
geposted 43 minutes ago
